4 pot vs mini 6 pot
leobardo79
4 pot vs mini 6 pot
Post by leobardo79 » Mon Jan 23, 2012 8:22 pm
Hi all, planning a bbk upgrade for my new ride cl7r. Not sure what is main diff or pros n cons between 4 pot n mini 6 pot. Any bros here can give some advice? Also can Jbt 4 pot fit cl7r?
AlanZ
Re: 4 pot vs mini 6 pot
Post by AlanZ » Sat Jan 28, 2012 12:52 pm
leobardo79 wrote:Hi all, planning a bbk upgrade for my new ride cl7r. Not sure what is main diff or pros n cons between 4 pot n mini 6 pot. Any bros here can give some advice? Also can Jbt 4 pot fit cl7r?
To fit a BBK into your car depends on ur rims size and offset also. Not just the model of your car.
E.g. if the bbK is 4 pot with 320mm rotor, it will not fit into any 15" or 16" cars.
leobardo79
Offset
Post by leobardo79 » Sat Jan 28, 2012 1:48 pm
Thx bro, let's say my 17" rims offset is +45, how do I know if this set of bbk can fit?
Seraphblade
Post by Seraphblade » Sat Jan 28, 2012 1:49 pm
Generally, 4 pot vs 6 pot, you do not really get more braking power. The brake torque remains the same.
Brake torque is dependant on coeff of friction, force applied, and moment arm.
By increasing the number of pots, you just cause the braking force to be applied more evenly. Or you can fit on a bigger brake pad. This allows the brake to heat up slower (as you have a bigger surface area now) and also can last longer (more material)
So the real comparison will not be 4 pot better or 6 pot better? A mediocre 8 pot will not perform as well as a branded 4 pot.
But usually the higher end kits uses more pots, this is for the spreading out of the brake force more evenly, and to last longer on track.
Ex: Honda Civic SiR (EK4) > Hyundai Avante
Current : Honda Accord Euro-R (CL7R) > BMW 328i (F30)
leobardo79
Post by leobardo79 » Sat Jan 28, 2012 3:45 pm
Seraphblade wrote:Generally, 4 pot vs 6 pot, you do not really get more braking power. The brake torque remains the same.
Bro thanks man I get a better idea now. Why are there mini pots around?
Also I hear people talk about brake bias. If change bbk n rear remain stock, are there any downsides of it? Thanks in advance
e240
Post by e240 » Sat Jan 28, 2012 7:21 pm
Turbo DC2 Type R
Proudly Sponsored by MFactory Competition Products for all Hondas!
TeamMFactory.com
