VAFC
chrisy
VAFC
Post by chrisy » Tue Feb 21, 2012 11:33 pm
Hi all, can VAFC install on non vtec vehicle.
Mugen Boi
Location: Lor Ah Soo, Potong Pasir, Bishan, Leng Kee, Hillview
Post by Mugen Boi » Wed Feb 22, 2012 11:28 am
u should b installing SAFC instead of VAFC :wink:
chrisy
Post by chrisy » Thu Feb 23, 2012 8:12 am
Omg alr bought. BUt can VAFC just use for monitoring n viewing purpose? If need to do a resale, how much can I catch?
Mugen Boi
Post by Mugen Boi » Thu Feb 23, 2012 10:10 pm
monitor purpose absolutely no problem
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Fri Feb 24, 2012 3:40 pm
chrisy wrote:Omg alr bought. BUt can VAFC just use for monitoring n viewing purpose? If need to do a resale, how much can I catch?
U still can use the Air Fuel tuning function.
Just that the Vtec control cant be used.
TCSS Emperor!
讲鸟è¯
chrisy
Post by chrisy » Fri Feb 24, 2012 5:22 pm
My ride is already tune with unichip, if I use the Air fuel tunning function will it disturb my unichip data?
Silver
Post by Silver » Sat Feb 25, 2012 12:13 am
chrisy wrote:My ride is already tune with unichip, if I use the Air fuel tunning function will it disturb my unichip data?
Yes it will.... Just use it for monitoring purpose instead then... :) :)
chrisy
Post by chrisy » Sat Feb 25, 2012 8:32 am
Thank Bro
yeobt
Post by yeobt » Mon Mar 05, 2012 9:34 pm
Hi, I'm a new ek3 owner, this VAFC is new to me n am keen to find out more.
Can someone tell me more n would it help to improve my car pickup cos I
feel that my engine is sluggish in the sense that I don't feel the surge power.
I suspect something is not correct but I don't know what.
Also, how much is a new VAFC?
After Spending So Much Time And Money To Own A Car,
You Must Learn To Enjoy The Fun Of Driving It,
Not Stressing Yourself On Your Journey Home.
Mugen Boi
Post by Mugen Boi » Tue Mar 06, 2012 12:15 am
best if u could send ur car 4 regular check...if nothing is wrong then look @ ur vafc
wat i meant was check ur air filter, ending oil, gearbox fluid etc
mileage of engine...whether need to overhaul engine etc
pokerface
Post by pokerface » Tue Mar 06, 2012 12:34 am
yeobt wrote:Hi, I'm a new ek3 owner, this VAFC is new to me n am keen to find out more.
just send to the right mech or ask a exp bro to test drive your car to give comment
ah_rek
Post by ah_rek » Wed Mar 07, 2012 2:11 pm
there is no mech i've seen that can properly tune a obd2 p2j 003 ecu on ek3 and maintain the 3stage vtec.
some mech can't even find the vtec point on VTI mode if you don't give them your ecu diagram, i kena that before!(it was even at a FAMOUS TUNING WORKSHOP)
you must understand that it runs on 12v lean, 12v, 16v and 16v wildcam mode.
if you read up on d-series.org even the angmohs advise you to throw vafc out of the window at high speed. lol
anyway, other dual vtec engines can see some 5-15hp gains on modded engines. There was once i met a esi with 160hp with vafc2
slow is gold.
kent_sg
Post by kent_sg » Mon Apr 16, 2012 11:51 pm
Hi all Bros,
For Vtec & Air/Fuel management, VAFC or PIGGY BACK ECU is recommended for CL7R?
Seitou
Post by Seitou » Thu Apr 19, 2012 11:57 pm
Hi all Bros,
I think for cl7r piggy back ecu is not as those stand alone ecu. As after a short period of time stock ecu will overwrite the piggy back.
kent_sg
Post by kent_sg » Fri Apr 20, 2012 7:52 am
Seitou wrote:
kent_sg wrote:
eeee78 wrote: U still can use the Air Fuel tuning function.
Hi all Bros,
Any good recommendation for standalone?
