Modding for pickup
kira
Modding for pickup
Post by kira » Wed Dec 08, 2010 12:52 am
hi guys
i drive a manual 05 dc5. and my overall goal is to mod for low end pickup
this are my current basic mods
-stock airbox with k&n filter
-catback 5zigen exhaust
-type-r 4.7 fd
-unichip Q tuning
(stock header)
can any of our lao chiaos here advise me on what i can mod next to further my goal
throttle body? intake manifold? header 421? flywheel?
thanks guys
kira
Post by kira » Wed Dec 08, 2010 12:53 am
maybe good grippy tyres too?
bugis_kid
Post by bugis_kid » Wed Dec 08, 2010 4:36 am
k24/k27
simple life for now
hongyi_2000
Post by hongyi_2000 » Wed Dec 08, 2010 7:04 am
bugis_kid wrote:k24/k27
+1 no replacement for displacement
1xian1
Post by 1xian1 » Wed Dec 08, 2010 8:57 am
lightening the whole car.. cf boonet, fender, door, boot.. remove all seats and panel inside the cockpit.
replace acrylic on all glass..
should improve quite alot on pick up.
chayfoocheong
Post by chayfoocheong » Wed Dec 08, 2010 3:39 pm
Can consider TB charge for 0.6bar.
UltraBear
Re: Modding for pickup
Post by UltraBear » Wed Dec 08, 2010 4:42 pm
kira wrote:hi guys
-type-r 4.7 fd
-unichip Q tuning
(stock header)
thanks guys
==> get the low end tuned... if unichip cannot tune low end, change to GReddy E-manage Ultimate...
dann
Post by dann » Thu Dec 09, 2010 9:08 am
tune your VTC with unichip
kira
Post by kira » Thu Dec 09, 2010 12:32 pm
tb charge to 0.6bar ?
do you mean tc?
e240
Post by e240 » Tue Dec 14, 2010 8:50 pm
gearing
learn to flat shift
really skinny tyres
Turbo DC2 Type R
Proudly Sponsored by MFactory Competition Products for all Hondas!
TeamMFactory.com
kira
Post by kira » Sat Mar 19, 2011 12:03 am
hi all
had to dig up this thread because of recent developments
just installed a dc sports header 4-2-1 (catless)
result
car seems more sluggish from pickup all the way to gear 5..dont really feel torque-y anymore. what could be the reason??
i thought 4-2-1 was for low end.. unless im wrong?
DIRT22
Senior Moderator
Senior Moderator
Answers: 1
Post by DIRT22 » Sun Mar 20, 2011 8:26 am
Try fitting back your cat and see how it goes....your described engine setup isn't heavily modified in any way, mostly bolt-on parts, so you may not be pushing anywhere near the amount of power to actually benefit from running cat-less (or a test-pipe). Have you tried your hi-rev hi-RPM performance as compared to before this latest mod? If that is suffering as well then you may be running an overall piping size that is not really that suitable for your ride. :!:
If you really prefer to run without a cat, try going for those hi-flow models from reputable brands. Either catless or hi-flow aftermarket cat will still fail inspection so it doesn't matter, but running catless the resultant exhaust smell is a dead giveaway for any experienced ROV officer. :P
If you don't wanna do any changes to your current setup, you can try fitting on an aftermarket ECU and have it tuned to "compensate" for this loss, although this isn't really the best way to go about it. Should fix the problem at the source, and not by adding things in haha! :wink:
kira
Post by kira » Sun Mar 20, 2011 7:38 pm
hmm perhaps if i go k24 it will fully utilize the exhaust profile?
alternatively.. i was considering tc
DIRT22
Senior Moderator
Senior Moderator
Answers: 1
Post by DIRT22 » Wed Mar 23, 2011 11:35 am
Up to you, it's your wallet, and your choice of headaches when it comes to inspection time..... :wink:
