Bros, i need help here. Driving a 2004 es5 for 5 years till ystrdy engine dies off while stationary at traffic light stop. Noticed the battery light came on too. Anyway I quickly restart and is ok. But 1 hr later same thing happen again.
So far no prob in restarting engine, when accelerate also no prob but only happen in stationary mode. I just changed battery 6 months ago. Also usually when battery dieing off, cranking engine becomes a prob. But so far cranking engine is fine.
Also my car has no mods at all. Not sure if it's alternator.
Can any bros who exp the same symptoms before pls advise ?
Many thanks in advance
HELP! Engine dies off when stationary
Re: HELP! Engine dies off when stationary
iceberg77 wrote:Bros, i need help here. Driving a 2004 es5 for 5 years till ystrdy engine dies off while stationary at traffic light stop. Noticed the battery light came on too. Anyway I quickly restart and is ok. But 1 hr later same thing happen again.
it's your alternator that is not charging..cos your battery check light light up
better get it check n change it...if not it will drain off your battery too
HOP Honda Original Parts........
- UltraBear
- 7000rpm VTEC ON
==> check if the terminal is secured properly... may be just loosen and looses its connection from time to time...iceberg77 wrote:Thanks for the advice. Now getting more frequent, even happens when slowing down. There be a slight judder then engine goes off.
Any idea how much and how long to repair alternator ? Also can pm me any recommended wkshps. Thanks
$50 vrepair up to -$200 recon seticeberg77 wrote:Thanks for the advice. Now getting more frequent, even happens when slowing down. There be a slight judder then engine goes off.
Always a winner behide is your looser...
- grandpa-VTEC
- 7000rpm VTEC ON
