some advice needed
charles
some advice needed
Post by charles » Thu Mar 04, 2010 1:57 am
how often do we need to change engine mounting? any good workshop to recommend and whats the damage like? thank you in advance!
Mugen Boi
Location: Lor Ah Soo, Potong Pasir, Bishan, Leng Kee, Hillview
Post by Mugen Boi » Thu Mar 04, 2010 9:55 pm
u dun change engine mountings often...u only change it when it's spoilt :wink:
daboy14
engine mount
Post by daboy14 » Fri Mar 05, 2010 12:32 am
you dont change/replace it unless its damaged/spoilt..
diiffrent brands out there it depends on ur application wether
race track or daily use..
charles
Post by charles » Mon Mar 08, 2010 4:08 am
thank you for the reply, here comes another question....how do u know it's spoilt? after change what will improve? knocking sound when moving off from standstill?
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Mon Mar 08, 2010 10:07 pm
charles wrote:thank you for the reply, here comes another question....how do u know it's spoilt? after change what will improve? knocking sound when moving off from standstill?
Vibration can be feel when engine is idling
TCSS Emperor!
讲鸟è¯
charles
Post by charles » Mon Mar 08, 2010 11:10 pm
Should be normal vibrations . Not very extreme. Then wat could be the problem be?
redeye
Post by redeye » Thu Mar 11, 2010 7:10 pm
What car are you driving if it an EG ,EK
it vibrate because it an old car dont sweat too much over it :)
ivant9029
10 000rpm Over Rev
10 000rpm Over Rev
Post by ivant9029 » Thu Mar 11, 2010 9:49 pm
Send to the workshop... 8)
charles
Post by charles » Fri Mar 12, 2010 1:49 pm
thank you for the replies. I'm driving an ES(2004), any good workshop to recommend?
Gresini
Post by Gresini » Sat Apr 17, 2010 9:26 am
2004 car eng mounting spoil???
charles
Post by charles » Sat Apr 17, 2010 9:54 am
Mounting no issue, lower arm bushing worn out
benade74
Post by benade74 » Sat May 01, 2010 11:13 pm
charles wrote:Mounting no issue, lower arm bushing worn out
I also drive 2004 ES5.. just change all my mounting at Autosaver Toh Guan..
charles
Post by charles » Fri May 07, 2010 2:57 am
Whats the damage like? thanks!
Gresini
Post by Gresini » Wed Jun 02, 2010 12:23 pm
Wah... All so rich... Change mounting...
I planning to inject silicone into my mounting...
CHEAP cheap upgrade+replacement!!! :lol:
dragger
Post by dragger » Fri Jun 04, 2010 11:11 am
Busted Engine mount can loose torque & power.
More vibrations when idle & even running.
You will know if its damage by looking on it, if its cracked or tear.
VTEC power!
