Questions for Spoon Brakes
Gresini
Post by Gresini » Mon Jul 27, 2020 8:12 pm
Hope someone still reads this forum... :lol:
For Civic FD1 (1.8) AT :oops:
Front rotor 282mm... stock :wall:
Can SPOON SPORTS TWIN BLOCK CALIPER SET(45020-DCR-G00) fits my car without any modification?
EG6/ EK4/ EK9/ DC2/ DB8/ GE8 share same brake pads model?
TIA :axe:
Jake
Re: Questions for Spoon Brakes
Post by Jake » Sat Sep 26, 2020 10:23 am
I am using Spoon caliper, RB1/S2000 rotor (300mm) and S2000 brembo brake pad. Direct fitting to FD2. You can find all the information on Spoon caliper here.
https://www.spoonsports.eu/news/caliper_intro/
https://www.spoonsports.eu/news/twinblock/
https://www.spoonsports.eu/news/calipers_part2/
Gresini
Post by Gresini » Sat Sep 26, 2020 5:27 pm
Hi Jake, I understand monoblock fits with 300mm rotors. It also comes with 2 alum alloy brackets for its radial mount.
Becos my objective is to avoid uprading to original rotors, (due to weight n cost).
I have checked dc2r uses identical rotors (except pcd / vent space) with FD1 (282) rotors. Now the main issue is mounting height. Both stock n twinblock are 140mm btw bolt centres, how about height? Becos i dont have DC2 knuckles drawing/info to compare. And nengun refuse to confirm if theu fit, i am worried. I dont wish to spend 2k only 2 calipers which i cant use or need to custom them to fit. Anymore ideas pls.
