Blown head Gasket
tF
Blown head Gasket
Post by tF » Tue Sep 17, 2013 10:20 pm
Recently, i've been facing the below issues:
1) Engine starting is not smooth
2) weird sounds from engine
3) High Temp
4) Milk choc liquid underneath engine oil cap
5) white smoke coming out from exhaust.
Are these all symptoms of a blown head gasket? If so, how much to change and any recommended workshop?
Thank you.
Silver
Re: Blown head Gasket
Post by Silver » Fri Sep 20, 2013 10:13 pm
tF wrote:Hi all,
3) High Temp
Thank you.
Yup, its a blown head gasket definately... You will need to do a top overhaul and change your piston rings... A job which probally might cost you around the range of $800.... :) :)
