Help on Honda Fit 2006 vibration/jerl issues
huiling12
Post by huiling12 » Wed May 08, 2013 12:07 pm
I am experiencing problems with my car since 3month ago till current.
When my engine is started n in P gear, my RPm will sometimes rave up and down by itself.
Also, when it is in the D gear, the car will jerk/vibrate before moving off.
Then occasionally, while I am on the move and coming to a stop, the car will vibrate before stopping and if i do not engage neutral gear, the vehicle will either continue to vibrate or the RPM will just rave up and down and my vehicle will jerk bad will the RPM comes down.
Is anyone having the same problem as mine and have had the similar issues rectify alrdy that can advise me what exactly it's happening? I have consulted a few car workshop and they suggested changing ATF, I have changed, but the problem is still not resolved.:(
Regards,
Hui Ling
cl7teckie
Post by cl7teckie » Wed May 08, 2013 12:09 pm
what kinda gearbox do u have?
huiling12
Post by huiling12 » Wed May 08, 2013 12:39 pm
@cl7teckie:How do I check what gearbox my car is using?
Regards,
Hui Ling
cl7teckie
Post by cl7teckie » Wed May 08, 2013 2:46 pm
huiling12 wrote:@cl7teckie:How do I check what gearbox my car is using?
Well, I mean, if yours is manual, auto, or CVT.
Also, the engine is 1.3 or 1.4 (not likely) or 1.5 ? i-DSL or i-VTEC.
From the above, sound like you have 2 problem. Any modification?
huiling12
Post by huiling12 » Wed May 08, 2013 2:59 pm
Oh. Mine is auto and 1.3 for the engine. No modification.
Regards,
Hui Ling
cl7teckie
Post by cl7teckie » Wed May 08, 2013 3:14 pm
[quote="huiling12"]Oh. Mine is auto and 1.3 for the engine. No modification.[/quote
AFAIK, JDM's FIT 1.3 only comes in CVT, and not normal Auto. Is this correct.
Also, being 2006 car, has your IAV being cleaned before by any workshop? When you said ATF? What fluid is used exactly?
As for the jerky during move off, I suspect that your gearbox's start clutch needs calibration. Any workshop do it liao.
huiling12
Post by huiling12 » Sat May 11, 2013 12:31 am
Sorry, I think so.
what is IAV? I just did the change of ATF in Jan.
Oh, calibration will do? How come the workshop i went doesn't tell me so?
Regards,
Hui Ling
cl7teckie
Post by cl7teckie » Sat May 11, 2013 8:20 am
huiling12 wrote:Sorry, I think so.
IAV -> Intake Auxillary Valve.
I need to know if the workshop changed with the right ATF fluid? A lot of workshop do NOT know the right fluid to use. CVT gearbox is very demanding in the fluid that is to be used.
How come they dont know!?...well, most workshop is NOT equipped with knowledge of modern cars.
shawnong
Post by shawnong » Mon May 13, 2013 3:20 pm
Hi, may i know how is calibration been done on start clutch?
A fast car is not fast. Unless the driver is fast
cl7teckie
Post by cl7teckie » Mon May 13, 2013 5:01 pm
There are a few official honda methods...but first, are you an engineer, and if you have the DLC box?
cl7teckie
Post by cl7teckie » Tue May 21, 2013 10:07 am
hah......another waste of time discussion. If not keen to follow thru, why even bother to come and waste other pple's time.. selfish
funkychicken
Post by funkychicken » Tue May 21, 2013 4:49 pm
Wow intake auxiliary valve. Suntin new. Where is it located bro?
Shawn for a start change oem honda fluid. At ur atf dipstick indicates what atf fluid it use. Normaly hmmf or cvtf. For a start get it drain and replace the fluid. Calibration of iav is sumtin new to me. Perhaps cl7 can advise u further. Else go to reputable shops. Or check out fit jazz forum for shop recommendation.
cl7teckie
Post by cl7teckie » Wed May 22, 2013 10:03 am
errr...calibration of IAV and also start-clutch on CVT should not be something new. This is very basic, that any guy servicing newer Honda engine must know.
What's hmmf fluid? you should this is recommended for Honda?
shawnong
Post by shawnong » Wed Jun 12, 2013 11:18 am
Hi Guys, i am driving a airwave, the gearboc dip mention hmmf.
hmmf come in a metal tin for the oil.
auto shop are selling at 68-72 per tin of 4L
the common use is CVTF come in white plastic bottle 3.5L $38-45
huiling12
Post by huiling12 » Mon Jun 17, 2013 3:43 pm
@cl7teckie: Sorry, was out of town. Couldn't be able to get the auto transmission oil name to continue the thread. there is a lot of term that is out of my range to understand. hmm.. PSPS!!
I need to rectify that problem in the coming servicing. So would hope for good advices from experts in the forum!!!:D
I called Kah Motor for advices on the jerks but they commented that honda Fit is imported series unlike jazz. They wouldn't be able to conduct full check.
Regards,
Hui Ling
