Advice needed - Electrical/ Electronic issue with FD2R
cousin
Post by cousin » Sun Dec 02, 2012 7:37 pm
Hi All,
I drive a 2008 FD2R and recently I've encountered an issue with the car that just won't go away. All my meters/ gauges (VTEC, fuel, temperature speed, tacho) will just continue jumping even after the car has cranked up. this will continue as I'm driving the car. I've tried to disconnect the battery (even changing new battery) and the problem remains. Any advice from exisitng FD2R owners appreciated (if you have encountered similar issue). If you can refer me to a preferred/expert FD2R workshop is much appreciated. Many thanks in advance.
speedsterdarren
Post by speedsterdarren » Wed Dec 12, 2012 3:53 pm
any OBD2 installed like RSM etc if got check wiring connection :wink:
