Starting Problem: Honda city VTEC 2006 model
ssathesh
Post by ssathesh » Mon Aug 27, 2012 11:00 am
Dear All, been having this problem for a month or so.
when turn key, car refuses to start.
sometimes in "P" mode have to move it a bit to start.
if cannot have to move gear to "N" and maybe car will start.
worse case is shift from "P"to "N"and in between car will start.
out of 5 times this happens 3 times.
can any kind souls offer advise / reason of this problem and est of the repair cost?
car is stock with batt stabilizer only. regular 10k servicing
elias
Post by elias » Mon Aug 27, 2012 11:37 am
From wat you hav said it seems like the gearbox position sensor is faulty,
send your car to a reliable workshop to hav it chk. Hope this could solve the problem.
funkychicken
Post by funkychicken » Tue Sep 11, 2012 6:12 pm
What elias said is correct. If ur sensor still sense its not in p mode, ur car wont crank.
