Do i need Rear camber kit for cl7
Posted: Sun Jul 29, 2012 10:07 am
by superlemonevo
Hi, I just bought a used cl7, n found rear tyre inner wear is serious as the car is lowered, the workshop told me have to buy camber kit else can't help to adjust much, just would like to learn from u what do I need to buy n what option is in the market, thanks ,91278747
help...
Posted: Wed Aug 01, 2012 10:16 am
by superlemonevo
any guru here to enlighten me?
Posted: Fri Aug 03, 2012 8:16 pm
by Z22
its a waste of money if you do not require camber.
just remember to rotate your tires every 5,000km or so
Posted: Tue Aug 07, 2012 11:16 pm
by superlemonevo
Thanks
Posted: Sat Aug 18, 2012 1:07 pm
by lfwd15
the stock coils has some amount of -ve camber already.
If you are on stock coils, dun bother. Just rotate the tyres often to even out the wear.
If you are on aftermarket coils, then get one to correct the -ve camber.
Hope this helps...
Posted: Thu Nov 01, 2012 10:43 am
by superlemonevo
can i know where to get cheap camber kit? can i get more positive camber with camber kit?
Posted: Thu Nov 01, 2012 11:57 am
by dfx
Suggest you dropby Kenny Alignment @ AMK Auto Point
I bet more then 50% of us visit him for alignment and camber advises
Posted: Wed Apr 24, 2013 11:09 pm
by funkychicken
Some car even stock coilover cant compensate the -ve camber due to alignment reason. Getting a camber to correct ur alignment for tire wear is a gd choice coz despite doin tyre rotation ur inner tyre will botak faster then the outer side.
Kenny alignment gives gd advice. My fren hyundai avante has thisncommon problem of rear camber -ve on one side n tire wear inside is bad to extend u can feel the steering vibrate after 2nd tire rotatiom. Only solution is to get aftermarket trailing arm suggested byby kenny. For ur case is camber bolt.
