help with honda city 4g vibrating issues
takenori03
Post by takenori03 » Sat Jul 07, 2012 2:24 am
when i start my engine and in P Gear, my RPm will sometimes rave up and down by itself.
when i try engage the D gear, the car will jerk/vibrate before moving off.
when on the move and coming to a stop, the car will vibrate before stopping and if i do not engage neutral gear, the vehicle will either continue to vibrate or the RPM will just rave up and down and my vehicle will jerk bad will the RPM comes down. this is occasionally happening.
can anyone advise me what is wrong with my car? i have changed the engine mounting, change the ATF,
noiseloops
Post by noiseloops » Wed Jul 11, 2012 11:07 am
hi, i had similiar issues but it was with a honda jazz. i believe it might be due to your gearbox. but again its just my assessment.
could be dude to prolonged/irregular atf fluid.
you might wanna try this guy eddie who runs his personal servicing. pretty gd at diagnosing faults. Eddie(buddyclub) - 92723423
elias
Post by elias » Mon Aug 27, 2012 12:00 pm
Firstly hav your engine mounting chk ,
then the TPS or ICV . But from wat u had described it seems like its gearbox problem.
I myself is also facing vibrations problem too and is trying to rectify the problem. :twisted:
funkychicken
Post by funkychicken » Tue Sep 11, 2012 6:08 pm
Have u change ur atf fluid? If not flush and replace with oem honda atf. My frens avante solved when discovered atf fluid was low and leaking. Replace new seal and flush ok. Rpm wise is throttle body and tps, hve it clean using stp carb cleaner.
takenori03
Post by takenori03 » Sat Nov 10, 2012 12:26 pm
i have changed my ATF, repaired the engine mounting, but the vehicle still at times have the same problem.. if its a gearbox problem, any place u can suggest?
funkychicken
Post by funkychicken » Fri Apr 26, 2013 4:53 pm
Can try eddie buddyclub. He is gd at diagnosis. But bit pricey I feel but his workmanship is gd. Urs is cable kind tb. The tps can be adjusted to certain voltage for wide open throttle and when closed. Clean tps and the maf air box sensor using electronic cleaner.dun touch wif ur hands. Drop by eddie place he open till late base on appointment.
takenori03
Post by takenori03 » Fri Apr 26, 2013 5:02 pm
I've cleaned the throttle body by flushing, but still same vibrating, and during reversing sometimes So bad the engine just die off.. Where is this Eddie based?
louis zhang
Post by louis zhang » Sun May 05, 2013 2:59 am
Should be engine mounting bro
hammerdin
Post by hammerdin » Sun May 05, 2013 2:00 pm
engine mounting should not cause unstable RPM and car should not die....
O2 sensor, trottle body, idling control valve. check these 3 as well..
funkychicken
Post by funkychicken » Wed May 08, 2013 1:46 am
Engine dies off and rpm fluctuates not related to engine mounting.
Call him at 92723423 Eddie. Need to make appt.
cl7teckie
Post by cl7teckie » Wed May 08, 2013 2:55 pm
How come this posting so similar to the other Fit problem har?
So City and Fit oso same problem gar...
shawnong
Post by shawnong » Mon May 13, 2013 3:35 pm
cl7teckie wrote:How come this posting so similar to the other Fit problem har?
Airwave also the same problem too.
A fast car is not fast. Unless the driver is fast
imahurdler
Post by imahurdler » Wed Jul 03, 2013 12:05 am
I believe City also use CVT gearbox? If CVT, the juddering issues and problems at starting off are common issues with the old Honda Jazz. Basically, change the ATF with the Honda CVTF. Your mechanic will know what it is if you say Honda CVTF. That will solve most of your vibration issues.
