I'm driving a GE06 Auto Fit with a problem of slightly long cranking whenever I start the engine from a cold state.
But still 1 turn and I was able to start the car.
Changed my battery and a new set of spark plugs. Initially thought was a power drain from the car alarm, power charger and the power amp. But after removing them, problem still persist.
Anyone have any insight as to what's the problem or have anyone to recommend that can help solve the problem?
Thanks!!!
Slightly Longer Cranking problem
Re: Slightly Longer Cranking problem
heeroyuy84 wrote:Hi all,
Thanks!!!
Bro,
You might want to check the following:
- Starter
- Distributor
- Fuel Pump / Filter
Just get your workshop to check
Cheers
funkychicken
