Erratic idling
esi06
Erratic idling
Post by esi06 » Tue Sep 27, 2011 10:08 pm
Help Help.....
Been driving esi for many years. This is the first time I encountered erratic idling for my ride. This morning, the moment the engine is started, the engine has erratic idling between 1.5 - 2.2k rpm.
What is wrong now?
brokencar
Post by brokencar » Tue Oct 04, 2011 11:35 pm
Does the erratic idling persist, or is it a one-time event?
esi06
Post by esi06 » Thu Oct 13, 2011 10:41 pm
brokencar wrote:Does the erratic idling persist, or is it a one-time event?
Happened when the engine is cold.
For one instance, I started the car and rest it rest from 10 mins. The erratic idling eventually reduces and the idling is normal after 10 mins. Have been monitoring it, same event happen.
kynoe_tan
Post by kynoe_tan » Tue Nov 01, 2011 3:57 pm
try cleaning your throttle body
aria
Post by aria » Mon Dec 12, 2011 4:12 am
It could be:
EACV/IACV, try to clean it.
Low coolant.
Vacum leak.
esi06
Post by esi06 » Mon Dec 19, 2011 12:34 pm
aria wrote:It could be:
Low coolant.
Vacum leak.
Cleaned the EACV/ IACV.
Same problem.
Finally replaced them and the problem is fixed.
pinkyshinky
pinkyshinky
Post by pinkyshinky » Sat Jan 14, 2012 1:41 pm
Today, most girls do become more quaid e azam videos
aware of the latest fashion sense.best it products in pakstan
For designers and brands,HP Workstations
ayrwind
Post by ayrwind » Sat Jan 14, 2012 4:21 pm
Normal lah. Early in the morning (6.30am) when I start my CL7R, the car idles at about 1.8k rpm, and will slowly decrease. If I drive off, the idling RPM will just drop down to 800. For the rest of the day, the car seldom go back to the high 1.8k levels. I think it is just some feature that increases the idling rpm when the engine is very cold.
