Vibrations when stopping (Fit 2008)
heeroyuy84
Post by heeroyuy84 » Wed Jun 01, 2011 12:03 pm
I'm a newbie to driving and starting some modding here. I just changed my car batt from the factory given to a amaron 45mah. An upgrade from the 35mah.
Somehow I notice some slight changes to the car engine.
1) less noise from engine - Not sure good or bad.. :?
2) Some strong vibrations after stopping the car. - This is where I'm feel might be a problem.
When I first start the car, with or without swtiching on the AC the tachometer always stays at 1000r. Everything feels normal. After a short drive, start to feel a slight increase in vibrations when I stopped the car and that tachnometer reads around 600r.. (Please refer to below image)
My car model.
Honda Fit 2008 GE version
From my past experience with my mum's old car, it's a problem but my situations is not as bad as hers. The vibrations will eventually stop her car's engine..
So I'm seeking out some advice from you guys. Hope someone can advise me.
Thank you
yazuka90
Post by yazuka90 » Sun Jun 05, 2011 11:40 pm
Try washing throttle body or getting a mech to check your IACV (idle air control valve)
[Yazuka90â„¢] SHC "V-tec Was Created By God to Bring Mortals Closer To Heaven"
-Darius-
Gresini
Post by Gresini » Mon Jun 06, 2011 1:09 am
Just a suggestion. Try back old battery. If problem solved than battery loh. If problem persist the battery just triggered something else. Go to a doctor.
khoo
Post by khoo » Thu Jun 16, 2011 11:17 pm
Maybe engine mounting gone liao.
Ask workshop to check cos auto car will damage engine mounting very easliy...
tailgatepro
Post by tailgatepro » Sat Jun 25, 2011 5:33 pm
is it CVT car? if yes, i read many comment, is very common start and stop with vibration.
