CEL help
vinng
CEL help
Post by vinng » Mon May 16, 2011 9:45 pm
The CEL on my EG9 comes one after driving hard for 5 mins, but goes off when I restart my engine. I retrieve the CEL code (code 1, oxygen sensor) with the CEL and engine on. However, I was told by my mechanic that this is not accurate as you need to retrieve the CEL with ignition on but engine off. Anyone has any experience to share regarding this? The ECU has been tested to be good (tested with a few of them and same CEL apprears) Thanks for your help !
abctech
Re: CEL help
Post by abctech » Sat May 21, 2011 12:10 am
vinng wrote:The CEL on my EG9 comes one after driving hard for 5 mins, but goes off when I restart my engine. I retrieve the CEL code (code 1, oxygen sensor) with the CEL and engine on. However, I was told by my mechanic that this is not accurate as you need to retrieve the CEL with ignition on but engine off. Anyone has any experience to share regarding this? The ECU has been tested to be good (tested with a few of them and same CEL apprears) Thanks for your help !
Your driving hard means you step on the accelerator and thereafter the CEL comes on?
Change your O2 sensor and the problem will be solved
