Creaking Door Hinges and door a bit Sag
eAgLe3yEs
Post by eAgLe3yEs » Wed May 04, 2011 1:47 pm
Hi guys, driving a 2 door car. If you guys are aware, the front doors are slightly longer and usually heavier. After years of open and closing, the door hinges will eventually sag and hence the alignment of the doors are not always well.
The door still closes, but it is like it is sagging. Does anyone knows where you can do back the door hinges to be align back?
civic_boy
Re: Creaking Door Hinges and door a bit Sag
Post by civic_boy » Wed May 04, 2011 3:06 pm
eAgLe3yEs wrote:Hi guys, driving a 2 door car. If you guys are aware, the front doors are slightly longer and usually heavier. After years of open and closing, the door hinges will eventually sag and hence the alignment of the doors are not always well.
they call the hinges butterfly..
