DC5 rear ARB bushings
evilfry
Post by evilfry » Thu Mar 24, 2011 10:20 pm
Hello
I think for mine the bushing is worned. Uneven surface causes sounds coming from the rear. Anyone knows where i can buy new bushings to replace?
thanks
Silver
Post by Silver » Thu Mar 24, 2011 11:07 pm
A few after-market brands you can look into... 2 of the more famous ones area Energy and Prothane... :) :)
evilfry
Post by evilfry » Thu Mar 24, 2011 11:13 pm
hey bro :)
thanks - DC5 is most likely 22mm right?
Looking at Energy suspension now, i see that some comes with endlinks as well..do we need that?
cheers
evilfry
Post by evilfry » Fri Mar 25, 2011 11:52 am
ok will be going to workshop to determine problem first - also found out mine is 19mm only.
cheers
James
Silver
Post by Silver » Fri Mar 25, 2011 8:26 pm
No problem... Determine actual problem 1st before proceeding... :D :D
evilfry
Post by evilfry » Fri Mar 25, 2011 8:31 pm
just went to the workshop today :)
Seems like it is not the ARB, but the rubber bushing that the rear left spring is sitting on. Where to get that part and replace? Any aftermarket types from energy suspension?
