check light
Vspeed 1
check light
Post by Vspeed 1 » Thu Dec 02, 2010 6:22 pm
I have problem starting the car when i have the check light on.
The problem start whenever the engine is cold or overnight.
The engine check light will only go off after a long wait like 5min.Then i can start the car.But if the car is park for a while after a drive to the next location.The check light will go off normal in 5sec.
Please advise what wrong with it.
I do not have any power loss or FC increase.No jerking or anything.Everything seen normal.Only the check light seen to take a little too long to go off.
Thank you
civic_boy
Re: check light
Post by civic_boy » Sat Dec 04, 2010 10:20 am
Vspeed 1 wrote:Hi,
Thank you
bro ur ECU got problem liao..... time to change car.... i wanna sell my car, u interested???? lolx
mugen_yaz
Re: check light
Post by mugen_yaz » Sat Dec 11, 2010 10:09 pm
Vspeed 1 wrote:Hi,
Thank you
having the same problem to bro...change ecu also same thing so now lan2 have to wait 4 check light 2 die off then can start.
civic_boy
Re: check light
Post by civic_boy » Mon Dec 13, 2010 10:48 am
mugen_yaz wrote:
Vspeed 1 wrote:Hi,
Thank you
mayb ur 2nd ECU oso got problem.......
