O ya, if i need to service my absorbers, is there anywhere that I can go?
Thank u all in advance!;)
DIRT22 wrote:Bearing in mind that your dampers are fixed to the car chassis/undercarriage parts unless the whole thing drops off or gets ripped off it's unlikely your dampers will fall off by themselves! And if yours is the coil-over damper design (meaning your coil springs are encasing the damper body) even if your damper fails totally you have the springs to support the car and let you limp to your workshop to have a new set of suspension put in. Newer designs with the spring separate from the damper will still be able to support the weight of the car just that if you find your car bouncing like mad don't go crazy on the corners anymore....
Have you seen unmaintained cars or taxis driving on the roads with the rears bouncing like some crazy jack in a box? They're probably running with gone case dampers and only the springs are supporting the car so every bump they roll over the car literally bounces loh.....
Plus, coil-overs almost always generate more noise than stock standard suspension sets. Putting in spring dampeners greasing the collars etc etc blah blah is not always productive and in my opinion unnecessary; enjoy the sporty feel that coil-over suspensions brings out for your ride, or stick to stock suspension and drive the car like the A-to-B runaround you'd prefer it to be heh heh..... Whichever option you choose, got to take the good and the bad together!
