Signal turn relay..where, what..is it?
boxster1
Post by boxster1 » Sat Jul 03, 2010 7:14 pm
Hi All,
I'm driving a Dec 2005 edix, 1.7 . Currently my right side signal indicator have intermitttent flashing problem. My car electrician says high chance the signal turn relay faulty.
But I don't have a edix service manual so don't know where the relay is located.Got a few relay under the steering wheel..tried but not the one. Call Honda Stocklist, not sure about the Part Number also.
Anybody can advice or got lobang..kindly help!
Thanks!
bengteck
Post by bengteck » Wed Jul 07, 2010 11:22 am
some electrician!
don't know how to solve problem they start to blame anything
normally signal lights fail due to bulbs going off soon or already failed
relay are simple contacts that do work base on ECU command
normally they are located at the driver steering below near obd connector
btw i've never heard of relay fail before!
wallaw819
Re: Signal turn relay..where, what..is it?
Post by wallaw819 » Tue Sep 21, 2010 10:37 am
boxster1 wrote:Hi All,
Thanks!
Have not changed anything in a long time liao (no problem with my 1.7L stream) but maybe the relay is in the fuse box under the hood.
There are a couple there.
UltraBear
Post by UltraBear » Wed Sep 22, 2010 2:29 pm
Thanks!
==> why dun you try listening to the clicking sound to locate the relay?
blackhammer
Post by blackhammer » Wed Sep 22, 2010 4:05 pm
bengteck wrote:some electrician!
Relay do fail sometimes... Search google and you will see lots of relay failure
