I am having misfiring when my oil temp rch abt 80 deg. Changed spark plug, spark plug cable, distributor, cleaned injectors and swap ecu but the problem still persist... Only left with opening up to check the engine.
Any bros out there know wats the cause of it???
Misfire when oil temp rch 80degree
- monzter_25
Re: Misfire when oil temp rch 80degree
Any mod done to the car?monzter_25 wrote:I am having misfiring when my oil temp rch abt 80 deg. Changed spark plug, spark plug cable, distributor, cleaned injectors and swap ecu but the problem still persist... Only left with opening up to check the engine.
