signal
civic_boy
signal
Post by civic_boy » Wed May 12, 2010 6:38 pm
Hi all, recently i change my signal buld to LED except my rear tail light. meaning front n side marker is change but after i change my signal blink faster.
anything i can do or do i need to change the relay??
thanks alot
Alvinyzw
10 000rpm Over Rev
10 000rpm Over Rev
Post by Alvinyzw » Wed May 12, 2010 7:01 pm
Is the voltage correct? :roll:
civic_boy
Post by civic_boy » Wed May 12, 2010 7:33 pm
Alvinyzw wrote:Is the voltage correct? :roll:
i'm using 12v bulb
benson83
Post by benson83 » Thu May 13, 2010 4:40 am
the signal will blink when a bulb is not present or it's burnt.
Meanin out of sudden, ur left signal blink fastfast, ur right signal blink normal, its tellin u left side got prob.
so left side from headlight, corner, side marker, tail light, brakelight, rear corner n reverse all u hav to chk. either burnt or missing. wad I know is that led dun hav the resistor thing in the bulb hence the wire system think its not present or burnt n blink fastfast.
for car, I not too sure, but for bike, there's this relay override addon thing to rectify this issue. maybe u chk wid those audio/accessories shop see if they can help.
tribute to My beat up DD
civic_boy
Post by civic_boy » Thu May 13, 2010 7:44 am
benson83 wrote:the signal will blink when a bulb is not present or it's burnt.
i tink i jus need the relay, where can i get it??
thks alot
