EG5 speedometer faulty
gjovi
Post by gjovi » Tue Apr 27, 2010 2:39 am
Hi seniors, am a newbie just bought an EG5 last month and have been having problems with my white sheet with green lighting speedometer.
Rav/speed/milleage all no problems
Problematic ones are: Fuel meter (Fails to hit "F" when i pump full tank, only goes up to the middle line and fluctuates around there, when nearly to empty tank it isn't accurate too) I can calculate my milleage but at times i forget, i'll be in deep shit lol. Haven had any occasions whereby the fuel light comes on because i pump way in advance which causes me inconvenience when i'm out without nearby petrol kiosk.
Water temp meter also doesn't move.
Any solution to this? Been wanting to change the speedometer but i couldn't find anyone selling, is there any shops that sells a fully working and functional speedometer? Would be an added point if the colour/light combination is nice too.
bra85
Post by bra85 » Tue Apr 27, 2010 4:11 am
tell u the possible solutions liaoz... :roll: :roll:
gjovi
Post by gjovi » Wed Apr 28, 2010 12:04 am
BRIAN!
yea thanks bro! btw a fellow shc trying to help me fix it up.
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Wed Apr 28, 2010 8:24 am
Can go to scrap yard to buy the meter cluster and have it replaced.
TCSS Emperor!
讲鸟è¯
daboy14
Post by daboy14 » Wed May 05, 2010 10:36 am
Before anything else bro check first ur sensor For the
water temp (thermostat) and for ur fuel just DIY ur tank
clean it up.. Maybe fuel Sending unit doesnt work properly.. Theres
no sense in buying a new speedometer assy if all ur sensors
are faulty..
Check it first before u buy.. Spend money well
"LIFE begins at 8.9k rpm.... VTEC power!!!
