After around 2 months of change of new knock sensor by MBM, I've have been called up to do the software (ECU) update today.
I was probably the guinea pig for MBM as it should took no longer than 1 hr but it took 3 hrs. Signal problem and could not be updated and took them quite a while and was sent to somewhere to rectify the signal problem.
Before the software update, I was already on the new sensor. Knocking can be heard at 2500rpm and 4500rpm.
After ECU update, i think 90% of the knocking is not heard. Still monitoring and the ECU will keep learning the new settings
So CU bros from Vincar please contact MBM for the hardware & software upgrade. I think if do the 2 together shouldn't take more than 4 hrs as they have experience now
