40k car service
Jnco
40k car service
Post by Jnco » Thu Mar 18, 2010 1:13 am
Dear all,
Do you guys know where is the cheapest and good shop to service for 40k civic 1.8. Kah motor charge me 500 plus for servicing! i'm down!
Fun Fun Fun.
nimm12
Re: 40k car service
Post by nimm12 » Thu Mar 18, 2010 11:34 am
Jnco wrote:Dear all,
try autosaver (defu or kaki bkt) - they follow the manual
Jnco
Post by Jnco » Fri Mar 19, 2010 2:17 am
Thanks bro. Shall it be cheap? worry. pocket gonna to have a huge hole. sianz
Fun Fun Fun.
nimm12
Post by nimm12 » Fri Mar 19, 2010 9:07 am
Jnco wrote:Thanks bro. Shall it be cheap? worry. pocket gonna to have a huge hole. sianz
confirm cheaper than KM
and they use original honda parts
finnicus
Post by finnicus » Mon Apr 05, 2010 2:48 pm
Hello guys,
I am quite new to this forum after having bought a 2nd hand CM4 recently. The car is going to hit 80k servicing soon, and I have done some research by googling and going through the forums, but is still unsure of the complete list of servicing items that would needed to be looked at, and hence hope to have some advice from the brothers here.
- Engine Oil
- Oil Filter
- Fuel Filter
- Air Filter
- Honda ATF
- Brake Fluid
- Water Pump
- Spark Plugs
- Brake Pads
Do we also need the following?
- Alternator Belt
- Aircon Belt
- Power Steering Belt
Is there anything else that I would need to also look into or anything that needn't really be done.
ivan98
Post by ivan98 » Mon Apr 05, 2010 5:59 pm
Gresini
Post by Gresini » Sun Apr 11, 2010 2:08 am
My own preference
Btw 5-10k - Engine Oil
Btw 5-10k - Oil Filter
no - Fuel Filter
no - Air Filter
Every 50k - Honda ATF
once every 2yrs - Brake Fluid
once every 2yrs - Clutch Fluid
no - Water Pump
Only whe misfire starts - Spark Plugs
Only change when worn - Brake Pads
Once a yr - Coolant flush
- Alternator Belt
- Aircon Belt
Regular check is sufficient
funtera
Re: 40k car service
Post by funtera » Wed Jul 21, 2010 9:30 pm
anybody can advise is autosaver charges cheaper than autobac?
kyan007
Post by kyan007 » Wed Jul 20, 2011 5:20 pm
Hi everyone,
After 3 years of servicing my Ody with Kah Motor, I wanted alternative workshop to service my car.
Do anyone tried using different engine oil @ Autosaver? I just don't feel like using Shell engine oil.
Any bro, can recommend workshow that know how handle our car properly?
Thank you.
