Anyone installed aftermarket suspension on CU2?
texter
Post by texter » Thu Jan 21, 2010 11:57 pm
Has anyone tried any aftermarket suspension? any feedback?
Any other options beside Mugen suspension?
weaver87
Re: Anyone installed aftermarket suspension on CU2?
Post by weaver87 » Fri Jan 22, 2010 1:46 pm
texter wrote:Hi,
May be u pm bro James....he used to mod a lot.....n now he is riding a CU2!! 8)
ultaman
Post by ultaman » Fri Jan 22, 2010 7:10 pm
Hi Guys,
about the suspension. Do any of CU2 Bro feel that the Oringinal suspension is a bit... how should i say.. Like not good enough. Even on small bumps the car shake quite hard. Like not comfortable enough.
It's like a 1.6 litre car suspension. What you guys think or is it just mine?
texter
Post by texter » Fri Jan 22, 2010 10:58 pm
ultaman wrote:Hi Guys,
Yes, I feel so too. the suspension is too soft to my liking.
James_Low
Post by James_Low » Sat Jan 23, 2010 10:40 am
Hi, why dont you guys try to do a test with your car... shift it to S mode and downgear to 2 gear and do a sharp cornering, slow in fast out... you will feel the differences and realise that the stability is actually there... CU2 are very heavy on the front and this result in the feeling that the suspension is so soft...
To my own opinion, unless we are very hardcore driver, if not there is really no need to look into the suspenion. The most is to change the adsorber to something which is slight harder... Apparently, the under carriage for CU2 is almost the same as CL7 except for the back if i am not wrong... so maybe you guys can ask any bros from the CL group to recommend good adsorber...
James_Low
Post by James_Low » Sat Jan 23, 2010 10:42 am
weaver87 wrote:
texter wrote:Hi,
Bro, i only do a little bit only la... no heavy mod le... when i got the $$$$ to go into heavy mod, i will jio u along... The most we drop in a TD07 and off we fly off..
