Overheating Water
vinceh
Overheating Water
Post by vinceh » Mon Jan 04, 2010 8:59 pm
hi bros, hope can garner some expert opinion here.
recently had some overheating which caused the water to go about 100C and rising. of course din continue others engine might kaputt.
initial checks found that the radiator was not turning
some technical info: hope you can correct me if wrong. the radiator fan is activated by the thermostat which switches on the Radiator Relay when a temperature exceeds the thermostat setting. mine is about 90C.
so i checked the radiator fan, the relay switch and the radiator fuse. all ok.
just wanting it to run smoothly, i just hardwire the battery to radiator fan. so now fan working.
but the temperature is still rising! why?
Mugen Boi
Post by Mugen Boi » Mon Jan 04, 2010 9:24 pm
did u check whether if there's enuff coolant :?: :wink:
vinceh
Post by vinceh » Mon Jan 04, 2010 9:51 pm
Mugen Boi wrote:did u check whether if there's enuff coolant :?: :wink:
checked. the reservoir tank was near the low. so i topped it up to max.
after running for a while, the level of the surge tank did not drop.
so issit the coolant was filled? or was there any air pocket?
Silver
Post by Silver » Mon Jan 04, 2010 10:47 pm
Maybe radiator stuck or water pump spoilt?? :roll: :roll:
vinceh
Post by vinceh » Mon Jan 04, 2010 10:56 pm
Silver wrote:Maybe radiator stuck or water pump spoilt?? :roll: :roll:
anyway to know whether the water pump running? or how to know radiator "stuck"?
terumo
Post by terumo » Tue Jan 05, 2010 1:24 am
Check ur radiator level when cold. Is it filled to the brim?
Every m0ment is an0ther chance... (",)
vinceh
Post by vinceh » Tue Jan 05, 2010 11:11 pm
after much assessment, i think it's the radiator kaputt.
any good cheap local workshop that works on cooling system/ replacement of radiator?
any ideas about the cost?
vinceh
Post by vinceh » Sun Jan 10, 2010 6:33 pm
vinceh wrote:after much assessment, i think it's the radiator kaputt.
any recommendations in the Woodlands area?
daboy14
Post by daboy14 » Mon Jan 25, 2010 11:20 pm
are you leaking water coolant??
if so much better if you buy the whole assy radiator with fan
lots of surplus at ubi..
plus check ur thermo stat if it goes auto when proper temp is reached
and lastly check ur upper and lower rad hoses maybe it needs some
changing..
just my two cents..
"LIFE begins at 8.9k rpm.... VTEC power!!!
