FD4 06 auto - moving off problem...
cjcz7782
Post by cjcz7782 » Sun Dec 27, 2009 12:02 am
Hi bro..
got my 2nd hand FD4 auto...
Currently after driving a month or so, i notice that when moving off and its change to 2nd gear, i heard some cranking (or rather sort of metal vibration) for 1-2 sec.....
sometime it is like clutch is not put into gear properly ( in term of manual gearing).. after much trying and testing.. i found that usually at 1st gear when hit 2.3-2.5k rpm, the gear will engage into 2nd and that is the sound was heard. this sound thing do not alway happen.. how and wat causes it is still unknown to me.
ANyone had this experiece??
Send for checking, no firm result.. end up do some routine checking.. mech feedback that the tension and timing belt are loose... good to change it.
not sure if this is the problem.. need u experience for some advice.
thanz.
Carnut1420
Auto
Post by Carnut1420 » Thu Dec 31, 2009 3:55 pm
second hand things are always bad.
dupontregistry
Car nut
Carnut1420
Post by Carnut1420 » Sun Jan 03, 2010 5:18 am
That is cool!! I feel affection for, standard, stable, and good-looking! I don't have any work practice with this company before, do you just heard about it or have their services, what is your skill with them.
dupon registry
Car nut
Carnut1420
Post by Carnut1420 » Mon Jan 04, 2010 4:31 am
Thanks you!!! I LOVE the new selection!!!
dupon registry
Car nut
Carnut1420
duponregistry
Post by Carnut1420 » Tue Jan 05, 2010 3:45 am
Its really nice post....
I just liked it....
Thanks....
dupon registry
Car nut
VW200
Post by VW200 » Tue Jan 05, 2010 4:22 pm
wat the millage, try changing ATF . :lol:
nic999
Post by nic999 » Fri Aug 12, 2011 4:26 pm
have you figured it out what is the problem ? I got similar situation as you too.. :(
Accord
RuLZz
ACRA
Post by ACRA » Sun Sep 04, 2011 6:50 pm
Hi Hi,had checked with the pro man ,Eric who had invented the S$50.00 fast & furious invention.
He asked you to go Kah Motor and request for a ECU programme update, gurantee will solved your problem
