bro whats the problem huh? fuse?
i am on eagle headlamp.. when on small light.. both side(left hand side and right side) circular pole light + 4 led light all doesnt light up.. rear lamp x4 also doesnt light up..
only able to light up main headlamp
only small light and rear light not working, somemore is both side.. so weird..
fog light is working... signal light working..
any remedy? ..
pole light and rear lamp both doesnt light up !!
yah done with that.. it's the fuse problem .. most likely cause by the eagle headlamp.. after changing of fuse.. one side angel ring both blown liao..bengteck wrote:There's two ways to locate the correct fuse (with some investigation skill)
- in the vehicle manual locate under maintenance - fuse location section
- above the fuel pedal, there's a panel with the fuse type printed on it
fyi relay will not black out the rear lamp, something shorted circuit will
now i gotta change out the whole eagle headlamp back to stock due to too mani problem with that lamp!!!
