Why I on aircon car become like that...???
- Mikhael SKY
With no aircon, the car very smooth, ever ready to pounce. But once the compressor is on, the car is like dragging half a tonne of boulders at the back.
Is this normal, or something wrong with battery or elsewhere? Or simply my car the horses too small...
Anyone can advise the ignorant here?
Thanks.
Thanks.
- Mikhael SKY
airborne
- Mikhael SKY
- Mikhael SKY
- Mikhael SKY
on light and on radio dun feel any effect, but the aircon is the killer, can step more gas lah but waste petrol.
so at the moment, i just bear with the weather lah...
by the way who had heard of mygreenoil kind of stuff?
Regards.
Regards.
I have the most stock EK3 in Singapore, and I hope it can remain that way.
- diversify_diversify
Re: Why I on aircon car become like that...???
Me thinking of stand alone air-con for my car, is there such thing??Mikhael SKY wrote:With no aircon, the car very smooth, ever ready to pounce. But once the compressor is on, the car is like dragging half a tonne of boulders at the back.
Thanks.
lack of power with aircon
Honda vtec engine are build and design with power band coming in between mid to hign rpm .when rpm below 3k with aircon this cause the engine to lose even more power this explain why you feel the lack in power . From what i know only buses are using separate engine to run the aircon
- Mikhael SKY
Re: lack of power with aircon
wow this thread unexpectedly got revived.....redeye wrote:Honda vtec engine are build and design with power band coming in between mid to hign rpm .when rpm below 3k with aircon this cause the engine to lose even more power this explain why you feel the lack in power . From what i know only buses are using separate engine to run the aircon
I was thinking if I should just install a fan in the car will do...just like the good old days in the taxis...but very embarassing
Does it make any difference in power consumption if I on the fan but not the aircon?
Fan are drive by eletricity from your battery will no affect your power don't worry .Air con compressor are driven by the engine directly this explain why alot energy is lose .Don't forget engine need to run power steering pump and alternator also somemore in old car alot of sensor is not feeding the accurate infomation back to ecu this reduce engine efficient .
- Mikhael SKY
yup u are right. I just verified this using the vacuum meter. Engine at idle the meter shows about 22 unit. On the fan w/o aircon does not appear to affect the reading. On aircon the reading drop about 4 ticks.redeye wrote:Fan are drive by eletricity from your battery will no affect your power don't worry .Air con compressor are driven by the engine directly this explain why alot energy is lose .Don't forget engine need to run power steering pump and alternator also somemore in old car alot of sensor is not feeding the accurate infomation back to ecu this reduce engine efficient .
Well, no need to buy fan liao, just use car fan w/o aircon. sometimes on aircon when cruising at higher speed, after awhile still can enjoy the cool air when aircon off and fan blowing...nice!
too much on off on off of air con in long run will destory it too.
