need help with spark plug analysis
jellyfish
Post by jellyfish » Fri Oct 23, 2009 1:56 pm
hi guys, i`ve just came back from my servicing, 20k oil change, on redline 10w-30 engine oil, and i decided to replace the sparkies to those iridium ones, that last longer(100k i heard) but i intend to change it out at 60k. oh ya my engine is stock F20C block .
here is the pics, am i running rich or lean, it seems like having some corrosion prob and carbon build up issues. hmm :?
how to prevent the build up of carbon? and is there anyway to tune the fueling?
the 4 sparkies, notice the rusty area
looks like carbon build up to me
theres a white spot there, seems like the sparks hit that spot onli
looks like rust too, any way to prevent it?
mango
TPAUL11
Re: need help with spark plug analysis
Post by TPAUL11 » Fri Oct 23, 2009 4:01 pm
Ur pulgs look normal,its just worn and due for change which u did.
KISS ME ARSE!!!
UltraBear
Post by UltraBear » Fri Oct 23, 2009 4:01 pm
these plugs have aged and worn off.... but certainly u're not running lean neither rich... the built up carbon is the result of poor sparks produced...
jellyfish
Post by jellyfish » Fri Oct 23, 2009 4:10 pm
hmmm, its platinium plugs, kah motor say they can last 100k, if thats the case i fear more liao :cry:
mango
Silver
Post by Silver » Fri Oct 23, 2009 7:26 pm
Plugs condition looks ok... Not lean nor rich... :) :)
