Accord Euro S folding mirror
AccordEuroOct09
- 1000rpm
Any idea where to install?
jackalcleo
jackalcleo
Is there a button to press on the door or it just fold up when you lock up the car with the remote alarm key???weaver87 wrote:Bros,
From my knowledge, there is no need to change yr side mirror when u want to install the auto close function. One or 2 of the CP bros had done it and it cost less $200 if I am not wrong...hope this helps...
cheers.
weaver87
The folding was installed and activated with your remote key. So, once u lock yr car, it will auto fold....suggest u pm bro Alloysious. He did his most recently. I guess they simply install a device inside yr side mirror.jackalcleo wrote:Is there a button to press on the door or it just fold up when you lock up the car with the remote alarm key???weaver87 wrote:Bros,
cheers.
AccordEuroOct09
- 1000rpm
I believe there is 2 kinds of thing we are talking nowweaver87 wrote:The folding was installed and activated with your remote key. So, once u lock yr car, it will auto fold....suggest u pm bro Alloysious. He did his most recently. I guess they simply install a device inside yr side mirror.jackalcleo wrote:Is there a button to press on the door or it just fold up when you lock up the car with the remote alarm key???weaver87 wrote:Bros,
cheers.
1. Auto folding when lock alarm
2. Folding mirror - JDM model only
You need to have folding mirror in order to install auto folding when press alarm button.
I checked $140 to install auto folding but my euro version does not have folding mirror funtion so cannot install.
I do not need auto folding, i think the euro version owner here might just want the basic folding mirror.
jackalcleo
weaver87
I think they sure have....may be yr version should be installed with SR-9 accord instead of using CP version. I noticed that CP version comes with signal lights on the side mirror but yr CU version dont.lingamair wrote:Bro, u got lobang for GZ shops?weaver87 wrote:yes, our CP models also comes with both tilt and folding mechanism. May be u should get hold of a set from overseas and install locally here......cheers!:D:D
So, if the SR-9 Accord version fit...then I think u got the best of both world!
I suggest u check any web site and determine if the latest accord SR-9 version can fit yr CU...if can, I will help u make a few calls....
cheers!
If I'm not wrong, the SR9 is the same body as our CU2. Can get more than just the folding mirror, can get the LED tail light also wor. Our CU2 also got side mirror turn signal wor, not as bad lehweaver87 wrote:I think they sure have....may be yr version should be installed with SR-9 accord instead of using CP version. I noticed that CP version comes with signal lights on the side mirror but yr CU version dont.lingamair wrote:Bro, u got lobang for GZ shops?weaver87 wrote:yes, our CP models also comes with both tilt and folding mechanism. May be u should get hold of a set from overseas and install locally here......cheers!:D:D
cheers!
AccordEuroOct09
- 1000rpm
LED i like....any bro here know how to get it i sure buy....lingamair wrote:If I'm not wrong, the SR9 is the same body as our CU2. Can get more than just the folding mirror, can get the LED tail light also wor. Our CU2 also got side mirror turn signal wor, not as bad lehweaver87 wrote:I think they sure have....may be yr version should be installed with SR-9 accord instead of using CP version. I noticed that CP version comes with signal lights on the side mirror but yr CU version dont.lingamair wrote: Bro, u got lobang for GZ shops?:D:D
cheers!
SpeedMaster1979
Hi guys,i did this feature at Chuan Sing for S$80, it is a module integrate to my stock key with lock/unlock(It is not an alarm,but just lock & unlock device with my car key,don't know how to describe it).
So when I lock my door,the mirror automatic fold in and when unlock,it automatic unfold.
As I don't want to install an aftermarket alarm cos I prefer my car keys integrate with my lock & unlock device and i always have this problem that when I lock the car,i forgot whether I lock or not?
So with this device,when i see that my side mirror is fold,i know my car is lock
Speed is nothing without control
