by installing it, will it somehow affect the FC? how about performance wise? thx for sharing
Air filter & air intake
hi bros, im confused between air fitlers and air intakes. is it to make the rpm more responsive? but whats the difference between the two.
Re: Air filter & air intake
air filter is part of an air intake system.DeeP wrote:hi bros, im confused between air fitlers and air intakes. is it to make the rpm more responsive? but whats the difference between the two.
upgrading to an aftermarket air intake generally improves FC and performance, but by very small amount. you can't really tell the difference in power unless you do a dyno.
Treat a car like a human. It needs healthy diet, care and grooming, and most importantly, exercise.
bro means air filter is classified under air intake?calvin_ wrote:air filter is part of an air intake system.DeeP wrote:hi bros, im confused between air fitlers and air intakes. is it to make the rpm more responsive? but whats the difference between the two.
air filter is a just 1 part of the air intake system.DeeP wrote:bro means air filter is classified under air intake?calvin_ wrote:air filter is part of an air intake system.DeeP wrote:hi bros, im confused between air fitlers and air intakes. is it to make the rpm more responsive? but whats the difference between the two.
like harddisk is just a component in a computer.
ok thx bro i understand nowcalvin_ wrote:air filter is a just 1 part of the air intake system.DeeP wrote:bro means air filter is classified under air intake?calvin_ wrote:air filter is part of an air intake system.
It may..DeeP wrote:ok thx bro i understand nowcalvin_ wrote:air filter is a just 1 part of the air intake system.DeeP wrote: bro means air filter is classified under air intake?
like harddisk is just a component in a computer.anyway the FC will not increase right?
- fiqueudrue
direct replacement of air intake to aftermarket does not improve fc or performance.
just a saving cost factor laa, no need change any air filter even after 100000km or so on, something like that..... imho
cone type air filter where loud vroom vroom bassy sound can be heard must change the stock air intake to fit in this cone thing la, does not improve fc cause when whack hard, jialat the fc. suitable for manual car. auto oso can la but low end die. imho
how still ok bo?
how still ok bo?
