Coolant
jasonjazz
Coolant
Post by jasonjazz » Mon Aug 10, 2009 3:52 pm
Dear All,
Recently I encounter this problem of water not enough at the opening when we have the radiator cap. I top up every morning. I discovered that the water was actually being suck into the reservoir i think, cos the water in the reservoir increases over time. What could be the problem? Please advise. I dun think is the head gasket problem. I had my radiator changed recently, things are working fine after changed only last week problem surface. I also changed both the radiator fan and air-con fan. BTW, my mileage is 210000km.
patan
Radiator
Post by patan » Thu Aug 13, 2009 10:51 am
The radiator should not be full to the cap, especially when the engine is cold. The reservoir act as a buffer for the radiator when it is heated up and the coolant goes back into the reservoir. If there is no leakage, you should not be filling up the radiator all the time.
jasonjazz
Re: Radiator
Post by jasonjazz » Thu Aug 13, 2009 10:02 pm
patan wrote:The radiator should not be full to the cap, especially when the engine is cold. The reservoir act as a buffer for the radiator when it is heated up and the coolant goes back into the reservoir. If there is no leakage, you should not be filling up the radiator all the time.
thanks for the advise. Discovered the problem, my head gasket having minor leak. My plugs abit rusty :(
patan
Radiator
Post by patan » Fri Aug 14, 2009 9:39 am
Hi Jason,
Is your car still under guarantee?
If it is, should have it replaced free of charge.
If you need further assistance, let me know.
Cheers,
pat
jasonjazz
Re: Radiator
Post by jasonjazz » Sat Aug 15, 2009 12:28 pm
patan wrote:Hi Jason,
Cheers,
pat
Hi Pat,
Its not under warranty anymore. I think I might need to do the repair soon :(
patan
Leak
Post by patan » Mon Aug 17, 2009 8:50 am
Hi Jason,
Always the case, after warranty, things tend to fall apart, as though the manufacturer makes the parts to last only after the warranty period. haiya.. :cry:
jasonjazz
Re: Leak
Post by jasonjazz » Tue Aug 25, 2009 9:10 pm
ya lor, my gearbox up lorry after warranty up :(
