With A/C problem. Pls help ?
Post by 9534 » Thu Jul 09, 2009 9:34 am
After i on my air con. The idle is fine. Air con is cold. Got speed. But the problem is whenever i wanna change gear, u have to clutch in den release the accelerator right den the weird thing occur is once i release the accelerator the whole car will have a very heavy engine brake den normal and RPM can from 3k drop to 1k very very fast. Wads the problem man ? i tried resetting my ecu buy pulling out the fuse of the 15A and 7.5A. Den this problem still there. Sigh. Im driving ESI manual. Thanks.
VTEC
(Variable Valve Timing and Lift Electronic Control)
Apollo
Post by Apollo » Fri Jul 10, 2009 10:17 pm
have you tried driving without the aircon on?
if tat is normal, cud b the aircon compressor clutch siezing.
Shamie
Post by Shamie » Sat Jul 11, 2009 7:44 pm
u toking bout when u let go of accelerator .. ur rpm plunge to below 1k? i tot tht normal for esi(old cars) ?
ThE UgLy SiLvEr OnE!
