REAR BRAKE WEAR FASTER THEN FRONT???
SEOW SEOW
Post by SEOW SEOW » Mon Jul 06, 2009 5:10 pm
Hi, Does Anyone Have The Same Problem Like Me
Apollo
Post by Apollo » Tue Jul 07, 2009 4:37 pm
ur tyre got any offset issue?
Silver
Post by Silver » Tue Jul 07, 2009 4:38 pm
Check your brake distribution unit.... :) :)
Mach
Re: REAR BRAKE WEAR FASTER THEN FRONT???
Post by Mach » Tue Jul 07, 2009 6:26 pm
SEOW SEOW wrote:Hi, Does Anyone Have The Same Problem Like Me
Front tires wears faster for FWD cars.
Mugen Boi
Post by Mugen Boi » Tue Jul 07, 2009 9:44 pm
most cars regardless fwd or rwd or awd...will have their front brakes wear out faster than the rear...b coz of brake bias n b coz of weight transfer...tat's y usually the front brakes r bigger than the rear n wear out faster than the rear :wink:
kolarsta
Post by kolarsta » Thu Jul 09, 2009 9:17 pm
unless u always pull handbrake at all the traffic light and tend to move off ur car for a split second b4 u release ur handbrake haha. or maybe ur front brake pads are more heavy duty than ur stock rear?
tow
Post by tow » Sun Jul 12, 2009 5:03 pm
your rears might be abit sticky. and the pads are rubbing on the disc at most of the times. have it checked and apply copaslip on the sides of the pads and the sliders.
6zeroG
Post by 6zeroG » Mon Jul 13, 2009 8:45 am
it may be that your brake pistons are jammed...provided you are running rear disc brakes...
Flat Four Intercooled Turbo......MAN MACHINE INTERFACE
Weapon Of Choice...
