Feedback for Ogura clutch
straightthru
Post by straightthru » Fri Jun 19, 2009 4:36 pm
Greetings!
Any brother or sister running on Ogura clutch and flywheel before?
Please provide me with feedbacks.
1)Wear Rate (normal driving)-can less 2yrs?
2)Replacement of clutch pad(cost)
3)drivability?
Any feedback is most appreciated!
Thank you!!!
benson83
Post by benson83 » Sat Jun 20, 2009 4:41 am
If u r talking abt the single plate metal one,
Wear rate is abt 12k km to 15k km, depending on ur driving style too.
Pad is abt 400+ to 500+ depending on where u get them too.
Drivaliblity depends on ur setup. But if u gettin new supersingle, aft the clutch bed in n it starts to grab, all hell break loose..... Esp if u got mounting inserts...
As for the carbon type, heard say quite easy to drive n last longer. u might wan to try that.
tribute to My beat up DD
ahchye
Post by ahchye » Sat Jun 20, 2009 1:41 pm
btw... izit all ogura super single clutch got the "ching ching" sound when pressed?? :)
DIRT22
Senior Moderator
Senior Moderator
Answers: 1
Post by DIRT22 » Sat Jun 20, 2009 5:45 pm
ORC Pro-Carbon clutch, single plate, very soft almost like stock clutch feel (ALMOST), very easy to get used to, easier on the legs than the multi-puck sports clutches commonly available....
Carbon disc also means really good endurance, of course this depends on how brutal you are on the clutch! An EG6 track car on this clutch did 500++ laps on SIC, when taken out the carbon disc looks almost new.... :shock:
Pretty expensive but I guess the durability pays for itself.....
As for the clinging sound, unless you are getting the damperless plate design models, ORC single plates will have that sound.... Usually if it is soundless it will be advertised as such!
This sound also gets progressively louder as the clutch beds in and/or gets worn....more free play available thus more space to "vibrate".....
straightthru
Post by straightthru » Sun Jun 21, 2009 11:28 pm
Thanks for all replies and feedbacks!!
If we compare cost effectiveness,Wouldyou guys choose Ogura or Exedy?
DIRT22
Senior Moderator
Senior Moderator
Answers: 1
Post by DIRT22 » Mon Jun 22, 2009 2:47 am
Coincidentally I was on Exedy 3-puck clutch set before I changed to Ogura, the Exedy wears pretty fast but for its price it is "relatively" affordable. The clutch action is old school, stiff but nowhere as "vague" a feel as stock clutch setups. It definitely is no 'light-action' clutch, but at its price range it is an affordable "starter-level" sports clutch.
The Ogura range of clutches should have better wear than the Exedy, but at a cost premium. Even the 'light-action' sports clutches from Ogura cost more, set for set. If you go up the range to the carbon types the cost gets a wee bit prohibitive, brand new. But if you manage to get more durability out of your set of Oguras, I think the cost factor MAY work out to be similar (of course depending on which model in the Ogura range you go for!)....
ahchye
Post by ahchye » Tue Jun 23, 2009 2:33 am
DIRT22 wrote:ORC Pro-Carbon clutch, single plate, very soft almost like stock clutch feel (ALMOST), very easy to get used to, easier on the legs than the multi-puck sports clutches commonly available....
thx for the info bro :D
