Door stuck........
Door stuck........
Please help. My rear eg door is stuck. Activate the child lock accidently, the outer handle is not working. How to open the door?
- sphinx_lover
- SHC Die Hard!!!
- MCDS
- Civic ES/EU/EP Moderator
no, the lever is at the edge of the door where it cannot be seen inside or outside the cabin. It's that space where the door mechanism catches the body mechanism to keep the door closed. it's on the door itself, do a good search every single surface if you still dun understand what i'm saying.
it's not at the bottom of the door.
it's on the side. inside, outside, middle side hahaha it's the 'middle' side.
Re: Door stuck........
need to do wat u usually see on tvabctech wrote:Please help. My rear eg door is stuck. Activate the child lock accidently, the outer handle is not working. How to open the door?
stick something into the door wth a thin long ruler to press the metal thing that will open the door.....
i dunno which workshop in sg can do but my shld have a lot
