My prosport vacuum gauge sometime will keep blinking like the background light on or off and the needles nor working. But after 5 min, it return to normal. Does anyone know wht is the problem? The air pipe drop off ? I remember when fixing my gauge, my mech never fix the fliter. Is that causing this problem? And when i step hard on my gas, the vaccum gauge show warning or peak. Is it normal? Please kindly advise me, thanks.
HELP !
best is to check with the installer who did this... but judging from your description, it does not seem normal on a Prosport ?
electronic gadgets are sometimes really hard to comment...
once i had upgraded my ECU.... one minute i was driving fine, later the vehicle was left stranded
towed back to my tuner and found out that the mechanic (being a greenhorn) did not connect the wiring into the harness correctly ....tough luck!
Haha.. shit just happen. Anyway i had solve my problem le. It is just the stupid sensor wire connect to my gauge, drop out ! Once connected back, it is ok le. Heng !Cougar_23 wrote:best is to check with the installer who did this... but judging from your description, it does not seem normal on a Prosport ?
electronic gadgets are sometimes really hard to comment...![]()
