ek3 gearbox oil leaking
jfit
Post by jfit » Thu Apr 23, 2009 3:56 pm
wat could be the problem?repair?change gearbox? ek3 can use esi gearbox?
which is the best way?thanks
Efhatch
Post by Efhatch » Sat Apr 25, 2009 8:18 pm
i need more info, where does it leak?
jfit
ek
Post by jfit » Mon Apr 27, 2009 12:18 pm
not very sure ,bottom oily.
floser75
Post by floser75 » Tue Apr 28, 2009 10:43 am
Common place for leakage :
- oil drain and refiller plug
- Drive shaft oil seal (left and right)
Sometimes, a leaky engine (esp the oil pan) may also cause the gearbox bottom to look oily. :wink:
Image Image
Scrap-In-Peace, EG6. You'll be sorely missed!
jfit
ek
Post by jfit » Tue Apr 28, 2009 2:54 pm
thanks alot.......
