Changing Speedometer Light Colour..diy?
airborne
Post by airborne » Sun Apr 12, 2009 3:45 am
Hi guys .. my ride came with a white speedometer and a switch below the steering to change it from Blue/Green.. personally i want it red.. or white? is it possible to DIY the colour change? if not.. any recommendations on where i can get it changed? do let me know .. thanks guys
SGTHAL
Post by SGTHAL » Sun Apr 12, 2009 7:23 am
can change but have to take out the el meter first, bulbs can be purchse from sim lim towers
ednab0y
Post by ednab0y » Mon Apr 13, 2009 12:55 pm
SGTHAL wrote:can change but have to take out the el meter first, bulbs can be purchse from sim lim towers
Bulbs or LEDs
airborne
Post by airborne » Mon Apr 13, 2009 7:06 pm
should be plug and play kinda diy right? no messing with circuit board/ wires and all that?
Silver
Post by Silver » Mon Apr 13, 2009 10:15 pm
Bulbs or LEDs
Bulbs... :) :)
airborne
Post by airborne » Tue Apr 14, 2009 12:00 am
el meter?
Silver
Post by Silver » Tue Apr 14, 2009 10:40 am
el meter?
EL is short for Electroluminescence......
Read here to understand more: http://en.wikipedia.org/wiki/Electroluminescence
:D :D
airborne
Post by airborne » Tue Apr 14, 2009 1:01 pm
Silver wrote:
el meter?
:D :D
thanks bro.
i just read the link..
hmm im not sure if i understand correctly.. the material used for the meter is such that it emits a glow when electricity is passed through it. and a different glow depending on the amt of electricty wired to it. thus mine is able to toggle from green to blue.
which is to say.. there is no bulb??
Silver
Post by Silver » Tue Apr 14, 2009 5:22 pm
airborne wrote:
Silver wrote:
airborne wrote: el meter?
:D :D
thanks bro.
Bingo!!!! You got it right for part one!!! :wink: :wink:
It is just a piece of material placed above your stock meters.... the stock meter still has bulbs.... wat bro SGTHAL means is to remove this EL piece from the meter and the original meter will surface... :D :D
fsf
Post by fsf » Tue Apr 14, 2009 6:43 pm
yeah. correct. becareful when removing the EL sheets. dun use too much force or else the needle might just break.
:lol:
airborne
Post by airborne » Wed Apr 15, 2009 5:06 pm
this sheet is behind the needle? hmm.. gotta tear around it? or remove the needle..damn scared i damage the needle.
btw so once i have it removed.. i just change the bulbs to fire red .. and its done ?
also .. mine are not stock.. the prvious owner installed this
fsf
Post by fsf » Thu Apr 16, 2009 1:50 am
airborne wrote:this sheet is behind the needle? hmm.. gotta tear around it? or remove the needle..damn scared i damage the needle.
yes. its behind the white sheet.
and why is your CEL light on? got prob is it..
airborne
Post by airborne » Fri Apr 17, 2009 3:41 pm
haha yep there was a problem so i took that pic. problem settled at s k garage
Touch n Go
Post by Touch n Go » Sat Apr 18, 2009 12:10 am
hi bros, i jus got a el meter for my EG6,
any idea how to install it?do i have to remove the original meter? wat abt the el meter connector?
im new to this car but would like to try diy myself :)
