My new fit 08 both headlight near signal got blurry spots!
8BallZ
Post by 8BallZ » Mon Apr 06, 2009 1:14 am
Ani1 happens to have the same problem as me?
Problem;
Both headlights near signal area got blurry spots. ( like dirty glass like dat )
Tried to clean it, found that the spots is from the inside of the headlight.
Isit a factory defect? but when i bought the car 7mths ago it was ok until recently saw it leh.
Thanks..
Silver
Post by Silver » Mon Apr 06, 2009 10:54 am
its call fogging of headlamps... happens due to water vapour inside your headlamp housing... Did you change your headlight bulbs recently?? :roll: :roll:
8BallZ
Post by 8BallZ » Wed Apr 08, 2009 8:49 am
Silver wrote:its call fogging of headlamps... happens due to water vapour inside your headlamp housing... Did you change your headlight bulbs recently?? :roll: :roll:
Since day 1 bought the Fit 08 on Sept 08 till now haven't touch the headlight bulbs yet leh.
Mayb during servicing of my car, vapour got inside..isit possible?
Then how do i get rid of it?
Thanks for the quick reply btw..hee
magixshoe
Post by magixshoe » Sun May 17, 2009 8:39 pm
alot of Fit are experiencing this. including mine. just go around and take a look and the rest..
8BallZ
Post by 8BallZ » Mon May 18, 2009 11:24 pm
magixshoe wrote:alot of Fit are experiencing this. including mine. just go around and take a look and the rest..
hi bro,
So is it consider a factory defect for our batch?
then how do u rectified it?
thanks..
Cougar_23
Post by Cougar_23 » Tue May 19, 2009 5:41 am
i got vapour stains after changing to aftermarket headlamps (not bulbs thou)
wat i did was to get the seller to apply silicon glue round the seals of the lamp (especially the top part nearer to our bonnet)
HOWEVER, DO NOT SEAL UP ENTIRELY.
Leave the base portion untouch ... simply bcos HOT AIR EXPANDS !!
Failure to do so will lead to your headlamps crack !
sphinx_lover
SHC Die Hard!!!
SHC Die Hard!!!
Post by sphinx_lover » Wed May 27, 2009 10:14 pm
Remove the both the headlamps and sun it. After that, let is cool down for awhile. Apply all round black weather-proof duct tape and tape all round the gap of the headlamp. You shd be able to prevent it from fogging during wet weathers :lol:
cscs3
Re: My new fit 08 both headlight near signal got blurry spot
Post by cscs3 » Fri Jun 19, 2009 7:13 am
8BallZ wrote:Hi,
Problem;
Thanks..
Same problem as Honda Civic. Send it back to agent for replacement under warranty. All the car will eventually get it. So make sure if you get it, replace it under warranty.
