Indicator light always on.. ???
Posted: Mon Mar 02, 2009 5:20 pm
by airborne
hi guys.. there is an indicator light thats always on ever since i bought my car.. even after servicing it doesnt go off.. i drive a 92 honda esi..
heres what is looks like
any brothers here know what the lighted indicator is?
thanks guys
Re: Indicator light always on.. ???
Posted: Mon Mar 02, 2009 9:12 pm
by TiburonTurby
Engine Check Light. Abnormal to be on all the time. Under usual circumstances, it indicates a problem. Pls send to a workshop for diagnosis.
airborne wrote:hi guys.. there is an indicator light thats always on ever since i bought my car.. even after servicing it doesnt go off.. i drive a 92 honda esi..
thanks guys
Posted: Wed Mar 04, 2009 12:56 am
by airborne
TiburonTurby wrote:Engine Check Light. Abnormal to be on all the time. Under usual circumstances, it indicates a problem. Pls send to a workshop for diagnosis.
thanks guys
Thanks bro..
i found a way to solve the problem.. but im not sure if its really solved.
upon insertion of key.. there will be three "stages" .. engine will start at the third stage. at the second stage, the equiptment running on electricity will start up.. at this point .. the engine indicator (as above) will light up .. the rest will stay unlit. it will hold for about 2 seconds.. and it will shut off itself.. at this point i turn my key fully and the engine starts : ) and the engine indicator light stays off.. now.. is that normal? or should i still get it checked?
Posted: Wed Mar 04, 2009 1:01 am
by airborne
thanks guys
Thanks bro..
Posted: Fri Mar 06, 2009 9:33 am
by bengteck
it could be electrical problem
but go down to a workshop and ask them to scan the car via the OBDII port
to confirm its electrical or mechnical
Posted: Fri Mar 06, 2009 10:39 am
by notevil
Go n check if there is any problem with your spark plugs or spark plug cable...
Posted: Sat Mar 07, 2009 1:22 am
by airborne
thanks guys.. the light came back on .. again. ill get it checked as soon as i manage to find a regular mechanic. scared kena chop
Posted: Sat Mar 07, 2009 1:50 am
by mjeng
alot of possible causes..
btw inform ur machanic to check on x'zos snsr..maybe not aligned.
Posted: Fri May 29, 2009 11:50 pm
by morish
thanks guys
try Mike at Kian Teong auto centre..64556268, specializes in CEL diagnosis.. fix mine after wasting time with 4 other workshops. This is not an easy problem to diagnose so go to the right workshop. cheers and good luck
cel light on
Posted: Sun May 31, 2009 11:40 pm
by redeye
This is not a small issue some sensor ,wiring or your ECU is having problem can meet up i can help with the dignostic by reading your ECU code .
Posted: Tue Jun 02, 2009 5:13 pm
by sphinx_lover
EG shd be using OBD I harness
bengteck wrote:it could be electrical problem
