Indicator light always on.. ???
airborne
Post by airborne » Mon Mar 02, 2009 5:20 pm
hi guys.. there is an indicator light thats always on ever since i bought my car.. even after servicing it doesnt go off.. i drive a 92 honda esi..
heres what is looks like
any brothers here know what the lighted indicator is?
thanks guys
TiburonTurby
Re: Indicator light always on.. ???
Post by TiburonTurby » Mon Mar 02, 2009 9:12 pm
Engine Check Light. Abnormal to be on all the time. Under usual circumstances, it indicates a problem. Pls send to a workshop for diagnosis.
airborne wrote:hi guys.. there is an indicator light thats always on ever since i bought my car.. even after servicing it doesnt go off.. i drive a 92 honda esi..
thanks guys
airborne
Post by airborne » Wed Mar 04, 2009 12:56 am
TiburonTurby wrote:Engine Check Light. Abnormal to be on all the time. Under usual circumstances, it indicates a problem. Pls send to a workshop for diagnosis.
thanks guys
Thanks bro..
i found a way to solve the problem.. but im not sure if its really solved.
upon insertion of key.. there will be three "stages" .. engine will start at the third stage. at the second stage, the equiptment running on electricity will start up.. at this point .. the engine indicator (as above) will light up .. the rest will stay unlit. it will hold for about 2 seconds.. and it will shut off itself.. at this point i turn my key fully and the engine starts : ) and the engine indicator light stays off.. now.. is that normal? or should i still get it checked?
airborne
Post by airborne » Wed Mar 04, 2009 1:01 am
thanks guys
Thanks bro..
bengteck
Post by bengteck » Fri Mar 06, 2009 9:33 am
it could be electrical problem
but go down to a workshop and ask them to scan the car via the OBDII port
to confirm its electrical or mechnical
notevil
Post by notevil » Fri Mar 06, 2009 10:39 am
Go n check if there is any problem with your spark plugs or spark plug cable...
airborne
Post by airborne » Sat Mar 07, 2009 1:22 am
thanks guys.. the light came back on .. again. ill get it checked as soon as i manage to find a regular mechanic. scared kena chop
mjeng
Post by mjeng » Sat Mar 07, 2009 1:50 am
alot of possible causes..
btw inform ur machanic to check on x'zos snsr..maybe not aligned.
morish
Post by morish » Fri May 29, 2009 11:50 pm
thanks guys
try Mike at Kian Teong auto centre..64556268, specializes in CEL diagnosis.. fix mine after wasting time with 4 other workshops. This is not an easy problem to diagnose so go to the right workshop. cheers and good luck
redeye
cel light on
Post by redeye » Sun May 31, 2009 11:40 pm
This is not a small issue some sensor ,wiring or your ECU is having problem can meet up i can help with the dignostic by reading your ECU code .
sphinx_lover
SHC Die Hard!!!
SHC Die Hard!!!
Post by sphinx_lover » Tue Jun 02, 2009 5:13 pm
EG shd be using OBD I harness :lol:
bengteck wrote:it could be electrical problem
