Vtec Controller
letdoit
Vtec Controller
Post by letdoit » Thu Sep 25, 2008 8:55 am
I am checking, for Vtec controller, can it control the air and fuel before VTEC cut in? Mean RPM between 900 RPM to 3000 RPM. can it be control fuel and air more?
2nd , Vtec controller can control when to cut in right?
UltraBear
Re: Vtec Controller
Post by UltraBear » Fri Oct 03, 2008 1:20 am
letdoit wrote:Hi,
==> if you're looking at something that controls the airflow and VTEC engagement, u can consider APEXi AFC-Neo or VAFC-II.
letdoit
Re: Vtec Controller
Post by letdoit » Fri Oct 03, 2008 1:26 am
UltraBear wrote:
letdoit wrote:Hi,
thanks. what abt v-tech controller? can do the same thing? controling the air and fuel.
UltraBear
Re: Vtec Controller
Post by UltraBear » Fri Oct 03, 2008 1:32 am
letdoit wrote:
UltraBear wrote:
letdoit wrote:Hi,
==> both APEXi AFC-Neo and VAFC-II has VTEC control feature ontop of the ability to manage the air flow.... btw, which Civic are you driving?
Civic EG/EK
Choice 1 : GReddy E-Manage Blue
Choice 2 : APEXi AFC-Neo
Choice 3 : APEXi VAFC-II
Civic ES
Choice 1 : GReddy E-Manage Ultimate
Choice 2 : APEXi VAFC-II
fiqueudrue
Re: Vtec Controller
Post by fiqueudrue » Fri Oct 03, 2008 4:08 pm
letdoit wrote:
UltraBear wrote:
letdoit wrote:Hi,
VTEC :twisted:
affiq
Post by affiq » Fri Oct 03, 2008 7:18 pm
vafc and afc neo can do the job..but..some guys told me that they find that vafc is actually better than afc neo..i dont know why cause i only used an afc neo and never a vafc for my ex car
letdoit
Post by letdoit » Wed Nov 05, 2008 12:13 am
anyone advise what is afc neo for?
beside can control Vtec, can it control fuel as is under fuel managment .
but reading the spec, every setting is about air and not fuel setting. can this also adjust how much fuel without adjust the air?
Shamie
Post by Shamie » Fri Dec 05, 2008 2:45 am
letdoit wrote:anyone advise what is afc neo for?
adjusting air input will con ur ecu into richening your car. vafc n neo will do that. If you want injector control .. you will have to go for slightly more advanced ecu pigs like emanage.
overwhelmed
Re: Vtec Controller
Post by overwhelmed » Thu Dec 25, 2008 12:25 pm
wat abt the difference btw unichip-q (or any other versions..) and apexi afc neo?
Do they perform the same task.. as in getting one of them will do or they have different functions?
bite me
Re: Vtec Controller
Post by bite me » Sun Feb 15, 2009 12:35 pm
UltraBear wrote:
letdoit wrote:
UltraBear wrote: ==> if you're looking at something that controls the airflow and VTEC engagement, u can consider APEXi AFC-Neo or VAFC-II.
Civic EG/EK
Civic ES
I'm driving CL7A, which brand is cost effective? does these brands hav all these features in 1? like: IVTEC controll, remove speedcut and manage air & fuel ?
Pls elighten..
Num3ga
Post by Num3ga » Thu Apr 16, 2009 11:57 pm
Im using a piggyback vtec controller just like the spoons vtec controller.It controls the vtec and nothing else.
To get the best engagement. U need to dyno it. Set it to engage at 7k rpm and look at the chart. the point where it dips it where the vtec needs to be engaged. U need to locate the highest rpm at which the hp dies on the non-VTEC lobe...then set it at that rpm then - 200rpm.Mine peaks at 5300k and i set at 5100k
Before anyone starts to recommend the Best VTEC Switchover Point for ur engine read this.
http://www.team-integra.net/sections/ar ... ticleID=59
Section IV.
But its still not optimize until u set the wide open throttle fuel map. So thats where the vafc,unichip and the others come in handy.
Im just happy i see the vtec light on :).
