Tein HA adjustment
KlowN
Tein HA adjustment
Post by KlowN » Mon Aug 25, 2008 11:25 am
hey bros.
im kinda lousy at this...
but how shld i adjust the stiffness of a Tein HA on my EG5?
i rem my mech turn the small knob at the tip of the coilover.
tot of adjusting it to my liking....any bros can advise?
tow
Re: Tein HA adjustment
Post by tow » Mon Aug 25, 2008 12:09 pm
KlowN wrote:hey bros.
that little knob is to tune the damping force. you got to turn it FULL clockwise to hardest setting 1st, then turn counter clock wise 8 clicks (factory setting) if not hard enough, turn full clockwise , then 1 click lesser (7 clicks)
i think tein HA is 16 hardness settings. 1 being hardest, 16 being softest.
cheers 8)
floser75
Post by floser75 » Tue Aug 26, 2008 3:04 am
Point to add...
Try not to exceed the 16th click (anti-clockwise from hardest).
The damper will up lorry very fast. :wink:
Image Image
Scrap-In-Peace, EG6. You'll be sorely missed!
pioneerpc
Civic EF/EG/EK Moderator
Post by pioneerpc » Tue Aug 26, 2008 3:57 am
yesh! totally agree!! learnt the hard way.. =(
floser75 wrote:Point to add...
ESI 2010-2012
Fit 2012-2013
DC5 2013-2014
Colt R 2014-2014
EK4 2014-2016
Wrx 2016-2017
Jazz 2017-2017
GTI 2017 -
KlowN
Post by KlowN » Wed Aug 27, 2008 2:51 pm
meaning not too hard?
tow
Post by tow » Wed Aug 27, 2008 2:53 pm
more clicks= more soft. the turn screw can go more then 16 clicks, but more then the recommended 16 clicks, the damper might spoil easily.
floser75
Post by floser75 » Wed Aug 27, 2008 6:07 pm
Yup! :wink:
As a rule of thumb, always start off by turning the knob fully clockwise, which is hardest. Then slowly go anti-clockwise click by click to find the setting you feel best for comfort and handling. Once u have reach 16 clicks, u shld not go further. If u still find it too hard at 16, then it is time to change spring rate or even the coilover. :lol:
Image Image
tow
Post by tow » Wed Aug 27, 2008 11:41 pm
floser75 wrote:
tow wrote:
KlowN wrote: meaning not too hard?
Yup! :wink:
well said bro! 8)
Movi$tar
Post by Movi$tar » Wed Sep 03, 2008 3:36 am
it should be tuned how much for track ?
n how much air should be pumped into the tyres for track ?
floser75
Post by floser75 » Wed Sep 03, 2008 11:10 am
Movi$tar wrote:it should be tuned how much for track ?
:shock:
Your questions are way beyond the scope of this thread. It is better for you to post a new thread. :wink:
PS: Damper and tyre pressure are just 2 out of many variables you will need to tune for track.The same setting that works for 1 car may not necessarily work for another. You will need to experiment with and also find something that matches your driving style. Hope I didn't frighten u away! :wink:
Image Image
Movi$tar
Post by Movi$tar » Wed Sep 03, 2008 4:49 pm
no problem...thanks alot...will try it out...
heric
Post by heric » Wed Oct 08, 2008 11:55 pm
hi guys, how much does a TEIN HA cost and where to buy?
tow
Post by tow » Wed Oct 08, 2008 11:58 pm
heric wrote:hi guys, how much does a TEIN HA cost and where to buy?
tein HA is out of production already. you can try your luck in the want to sell section in SHC forums. you should be able to gauge the price then..
tensaixp
Post by tensaixp » Fri Oct 24, 2008 6:26 pm
Hi i just got my Tein HA recently, how much softer the rear must be as compare to the front?
heric
Post by heric » Wed Oct 29, 2008 11:35 pm
oh.. ok.. then what would you recommend? mech say my suspension leaking....
