Loud screeching noise after brake pad changed
Sean
Post by Sean » Fri Jul 19, 2013 12:51 am
Is tat normal? Some say i need to skim rotor, some say leave it, it will go away by itself.. Any advice from any exp bro out here?
Rgds,
Sean
Teow Yiwei
Post by Teow Yiwei » Fri Jul 19, 2013 8:10 am
you using stock/OEM or some aftermarket brands? If it is a high temperature range pads it will always screech when cold.
