JBT Big 4 pot brake pads, need help pls!
goo
Post by goo » Tue Jun 12, 2012 9:32 pm
Hi if anyone could please share with me, what size pads or brand and model brake pads you got for your jbt big 4. i am currently using ferodo ds2500 racing, but it takes time for it to heat up cos for city driving, and my braking distance is long.
thanks alot for your help. could pm me or post here. :)
funkychicken
Post by funkychicken » Thu Jun 14, 2012 8:52 am
The higher the temp pad, the longer it takes to warm up. 300deg is sufficient for sg driving. Unless lotsa last min hard braking.
goo
Post by goo » Fri Jun 15, 2012 5:33 pm
funkychicken wrote:The higher the temp pad, the longer it takes to warm up. 300deg is sufficient for sg driving. Unless lotsa last min hard braking.
Thanks for replying, thats wat i read too. But those selling brake pads, insist on me getting high temp 800 deg pads, better friction, it takes 50deg to warm it up... Confused
WSLBCL7
Post by WSLBCL7 » Sat Jun 16, 2012 9:21 am
really depends what u intend to do? always track? if normal driving then dun nd 800, i think your rotor wun last long if u use 800 daily... :lol:
cactuswei
Re: JBT Big 4 pot brake pads, need help pls!
Post by cactuswei » Fri Jun 29, 2012 10:22 am
Hi Bro,
Mind if you share where and how much you got your ferodo for?
Currenly also on JBT Big (4) and most workshop told me no brake pads for my kit
& i hv to go bk to Y Bro
Cheers
goo
Post by goo » Fri Jun 29, 2012 11:18 am
cactuswei wrote:Hi Bro,
Cheers
It was from the previous owner, he had it cut n custom to our jbt.
I searched and no alternatives except endless, vttr, jbt.
