tikili
- 2000rpm
Post
by tikili » Mon Jan 09, 2012 4:23 pm
hi,
Need advice.
I have this circular scratch mark on my rotor (3 mths old) after changing into a new brake pad. It only happens on the left rotor, the right rotor is ok. Should i be concerned? or the workshop did not do the installation properly.
thanks
jellyfish
- 7000rpm VTEC ON
Post
by jellyfish » Mon Jan 09, 2012 9:59 pm
got foriegn object wedged inbetween pad and disc, have it pad removed and checked out, might be faulty pad , stone stuck or metal
mango
gadgetbearEG6
- 4000rpm
Post
by gadgetbearEG6 » Tue Jan 10, 2012 11:04 am
I agree with Bro Jellyfish. Something might be stuck there or there is a problem with the pad. Might wanna get it checked soon. the line on you disc looks quite deep man...
can ever stop modding?
tikili
- 2000rpm
Post
by tikili » Tue Jan 10, 2012 11:26 am
thanks for advise. will get it check soon.
the scratched rotor still can use right? (just got it change 3 mths ago)
jellyfish
- 7000rpm VTEC ON
Post
by jellyfish » Tue Jan 10, 2012 12:58 pm
tikili wrote:thanks for advise. will get it check soon.
its not too deep yet, i`ll say its still good to go, if its giving you the jitters then you might wanna have the rotors machined, but that will make your rotors thinner and add to the cost, luckily you are one of those owner who do periodic chacks on the items you just installed. good for you brudder, drive safe.
mango
tikili
- 2000rpm
Post
by tikili » Wed Jan 11, 2012 7:04 pm
went back to the workshop today and mechanics explain that sometimes it happen to new brake pad. but did not skim the rotor as it has to skim all front rotor and the pad too.
so monitor first to make sure there is no vibration at >120km/h.
jellyfish
- 7000rpm VTEC ON
Post
by jellyfish » Wed Jan 11, 2012 7:46 pm
tikili wrote:went back to the workshop today and mechanics explain that sometimes it happen to new brake pad. but did not skim the rotor as it has to skim all front rotor and the pad too.
vibration when applying brakes is due to warped disc, vibration duting a set speed is a out of balanced wheel
nothing to do with the pads
mango
tikili
- 2000rpm
Post
by tikili » Thu Jan 12, 2012 2:17 pm
is it possible that the wheel is out of balanced after the changing of brake pad process? Coz now my steering wheel is steering to the left, which i do not have this problem before the brake pad change. Or i am having a different problem now.
jellyfish
- 7000rpm VTEC ON
Post
by jellyfish » Thu Jan 12, 2012 3:17 pm
tikili wrote:is it possible that the wheel is out of balanced after the changing of brake pad process? Coz now my steering wheel is steering to the left, which i do not have this problem before the brake pad change. Or i am having a different problem now.
nope diff prob you are facing entirely
mango
tikili
- 2000rpm
Post
by tikili » Sun Jan 15, 2012 8:28 pm
EBC green
